On 5/11/2022 at 11:57 AM, the nerd said:
Gaggia Classic Pro
DF 64 Grinder...
Solid setup
I recently got the DF64, its a game changer. I thought my coffee was good, untill I got proper grinders. Your grinder is the most important.
  • Replies 7.4k
On 5/18/2022 at 12:33 PM, babse said:
Cleaned out my grouphead last night. First cup this morning was like from a brand new machine.
Felt like i got everything right 🙌😊
Looks great! If you need any spares for your Oscar let me know, I have a stripped one sitting in my garage... Boiler got destroyed!
I have a spare portafilter for it too if you want to cut the bottom off etc...
I might need to replace the steam tap on  my Oscar soon. For some reason it needs to be opened and closed to or three times before steam comes out.
Is it relatively easy to pull out and replace? Or should I bite the bullet and send it to the local guys for the repair?
You have to remove the main cover, but once it's off everything is right there.
Probably just the tap seals in there binding up.
Can't be that hard, I've pulled the three way valve out a couple of times when it decides to be a two-way, so I'll do the steam tap soon and see if it can be refurbished. Thanks!
So what cups do you guys use? I currently just have good ol' large mugs and tea sets. I'm trying to find some of the lower and wider type cups with 150 - 200 ml capacity.
The Acme flat white range looks really nice (Yuppy Chef, Truth). Maxwell Williams also have some plain options, bit a bit too "Curly" for my taste. Le Creuset too bulky. Dislike Carol Boys. A set like @babse's cup and saucer above is what I'm aiming for.
I'd recommend looking for local pottery artists/makers... if you're in CT, keep an eye out for the Rondebosch Potter's Market. you'll find some lovely stuff. if that's your thing of course
I went from our usual coffee and tea mugs straight to Acme.
They are expensive, but robust and should last a long time.
They do need to be warmed up before you make your coffee in there, as they are thick and will suck the heat out if you start from cold.
cheap and really good in my view...
they are Regent 4-Piece Set of Stoneware Tea Cup & Saucers
HCS Home and Catering do them, you used to get them off DailyDeals/OneDayOnly and now and then Takealot.
27 minutes ago, Frosty said:
Or should I rather ask if it’s the same one that is used by those who have one.
R12k is not a bad price given that Amazon has 4 different models from $1k to $1.4k
Might consider it, as the wife has her 1-touch, no frills bean to cup machine.
I am quite possibly wrong.
I thought the question related to the brands, but the specific models may have differences.
I don't know enough about La Pavoni.
Acme all the way.
Nice colors
Robust
Good sizing as well. The 150ml is perfect Flatwhite size if you want the coffee to punch through your milk.
The cappuccino (190ml)is also a good option.
If interested I might be willing to part 1 or cappuccino cups. Dm me.
23 hours ago, Frosty said:
Are these two machines the same spec?
Yes. But don't confuse the left one for a RRP. That's your typical overpriced import-commerce sites. Don't know how these sites exist...
Either way, same specs. Smeg just owns the brand now (for better or worse..). Internals are the same AFAIK.
In my brief experience, amazing machine. The attractiveness was the simplicity, involvement and beauty! (and availability in 2nd hand market). They have downsides, but not enough to put me off. This is way different to a one touch, but oh so satisfying to use. I can definitely recommend, but do note that everytime your wife wants a coffee you'll be the one making it.... I would even consider the pro version just for the included gauge and larger tank. Also, Hirsch had a 10% discount on these recently FWIW.
