Has anyone experimented with beet root juice? Apparently the nitrates in it can help with endurance efforts.
Usually taken before an event and 'dosing' during the days leading up to it. Obviously it's no silver bullet, but if it helps even marginally, could be interesting.
The available results suggest that supplementation with beetroot juice can improve cardiorespiratory endurance in athletes by increasing efficiency, which improves performance at various distances, increases time to exhaustion at submaximal intensities, and may improve the cardiorespiratory performance at anaerobic threshold intensities and maximum oxygen uptake (VO2max). Although the literature shows contradictory data, the findings of other studies lead us to hypothesize that supplementing with beetroot juice could mitigate the ergolytic effects of hypoxia on cardiorespiratory endurance in athletes. It cannot be stated that the combination of beetroot juice with other supplements has a positive or negative effect on cardiorespiratory endurance, but it is possible that the effects of supplementation with beetroot juice can be undermined by interaction with other supplements such as caffeine.
https://www.ncbi.nlm.nih.gov/pubmed/28067808
  • Replies 18.3k
Beetroot is a natural vasodialator I think. Increased blood flow must be good for endurance (?) This topic gets a lot of attention in strength training (boet), haven't read the endurance side
I'll drink it even if it's just for the placebo effect.  :ph34r:
I would not recommend it on the day, it has certain laxative qualities as well.
Definitely should be part of your normal diet though.
That is what happened to me on Saturday... I used Aim's beet powder... I was literally running from garage to garage. I guess your digestive system needs to get used to it.
I did. It works, no joke. I used it daily in smoothies and before a hard run I had a glass off 100% beetroot juice. Its hard to describe but it made a massive difference.
Only cons, my pee was blood red for weeks, and after about 3 weeks of my beetroot regime it started to give me the worst nausea imaginable. I couldn't stomach it since.
Edited by Mudsimus
Berlin Marathon nutrition supplier, ultraSports had beetroot based gels at one of the tables and also betroot energy drink. Was surprisingly good.
Is anyone using the Maurten products?
It is ridiculously expensive, so I am wondering if it is worth giving it a try.
I have read a couple of reviews and they all seem positive.
I use them. Normally only on long runs or races. It's water all other times. I've always been super nervous of what I drink during a run and normally just resort to water but have found the Maurten drink mix really good. I used to drink 32Gi and it resulted in pit stops. The Maurten drink is really easy to take in and easy on the stomach. I also use the Maurten gel. Never been a fan of gels but the Maurten is just so easy to digest.
I know you have tried lots of different options.
It might be worth giving Future Life a try. I mix a table spoon of the powder in a zip lock and run with that. When I need fuel i'll mix it with water and then bite a hole in the corner and squeeze it out.
Easy on the stomach and hydrating at the same time.
A new discovery was the Adapt Nut+Seed bars. They have them at Jacksons Real Food.
A friend of mine swears by a product called Generation Ucan. Also makes a paste out of their powder.
Have you guys ever run up a hill and past a cyclist? Can't believe it happened to me going up Southern Cross Drive this weekend.
Passed a couple people. Wasn't even running fast. 5 min/km
It happens more often than cyclists care to admit.....
Especially as the hills get steeper.
Then the mechanical advantage you get from a bike gets cancelled out by the extra weight of it.
In fairness, I find it a lot easier running up a hill than cycling up it. My wife told me that twice at Delta Park when she's overtaken a cyclist up that long hill they've pulled over and pretended to look at their chain like there's something wrong with the bike.
