Ok so how long before the RD touches the ground when you are in granny? 56? 58? Also, any views on the correlation between chain length and chain failure / wear?
Call me old fashioned, but I'll take my dinner plate on the front right next to my side plate opposed to on the back for now.
At the moment, the cage is the same length as the current xx1 & x01 & x1 & gx1 stuff, which means it goes no closer to the ground than current iterations, due to the way that the RD moves sideways, not diagonally. It stays in the same horizontal plane, with the upper jockey wheel moving in & rearward as you shift gears. X-Horizon, they call it.
The only change in the RD is that hte upper jockey is slightly more offset (rearwards) so that it can clear the 50t without having to extend the b-screw too much.
  • Replies 215
Myles you miight have missed when I said this:
"I like the idea of simplicity and less clutter on the bike, but at the end of the day it needs to be practical and comfortable to ride with"
I'll add that by practical includes affordable, having to wait for the trickle down to more affordable sram ranges is not cricket either.... And can u imagine how heavy that more affordable version will be if the top of the range weighs 355g
Price and a 8 tooth jump to a 50T cog don't make it practical to me. XTR used to be the benchmark for expensive mtb componentry but srams 11 and now 12 T cassettes have made xtr almost affordable in comparison.
Price and weight from chain reaction cycles:
XTR 11-34 or 11-36 = $138 (RRP $249)
On special
X01 10-42 = $251 (RRP = $450)
XX1 10-42 = $268 (RRP = $498)
Eagle10-50 = $360 to $420
Until I get a chance to try it I won't hate it, maybe I like it..... But I'm not falling for the marketing (500% range) or going fall asleep dreaming about it
Each to their own.
You either need it / want it based on the type of riding you do and can afford it or not. Regrettably with our exchange rate new product lines from overseas are getting pricy.
As to me my Enduro / trail bike will remain 1 X 11 XO and my fully ridged carbon 29er will stay 2 X 10 because I need not only the range but the smaller jumps as I use this bike as a road bike.
I do have plans on getting a short travel dual sys for riding such as the Dirtopia 100 miler on I recon that bike will warrant Eagle.
Remember to enjoy the ride.
After splashing on 1x11 already I can't see myself going to 1x12 just for the bailout gear.
I am quite happy on my 34t upfront and haven't found a hill I couldn't ride yet. Obviously if I am going to do an epic I might go down to a 32t to save the legs a bit.
Edited by Rudi Pollard
My question is this:
Will Shimano react and also go that route, after doing so much for riders with the M8000 11speed series?
Or will they do what any sane industry would do and invest in creating an economy of scale, allowing a trickle down to SLX level 11 speed drivetrains?
Cannot wait for Shimano to go 1 x 12.  On the Di2, it is a simple software upgrade with new cluster and chain.  Bring it on, apparently soon, soon...
