Dissipline Posted November 8, 2019 Share Does anyone else having problems with SRAM NX eagle group set?My rear derailer just broke and having issues with shifting for past 2 months. Jumping gears as well. Link to comment Share on other sites More sharing options...
T-Bag68 Posted November 8, 2019 Share Hay there Dissipline,Got the bike out the box, so all new components. After about 4/5 rides of a shortish distance, I had a jockey wheel fall out, and from what I've read, this is a regular occurrence. so maybe extra lock tight on those bolts. in terms of skipping gears, I also had this problem. I adjusted the barrel, I got top end shifting nice, and the bottom end shifting nice, but middle jumping like skippy the bush kangaroo... The problem seemed to be a slight bend in the hanger, a little fall or knock can send it out, I even got told that a bit of pedal force come send it out a little, so have a look from behind and see if it looks to hang at a slight angel. Good luck Link to comment Share on other sites More sharing options...
droo Posted November 8, 2019 Share Forum search. It's well documented. Link to comment Share on other sites More sharing options...
love2fly Posted November 8, 2019 Share My Eagle cage sits slightly skew but shifts like a dream, HOWEVER it is very sensitive.Check your B screw adjustment with the plastic Sram template. 1/4 turn can make a difference. Wimpieva 1 Link to comment Share on other sites More sharing options...
Captain Fastbastard Mayhem Posted November 8, 2019 Share How did it break? Did the jockey wheel come out? If so, then it's a well known fault that is easy to fix. Link to comment Share on other sites More sharing options...
HuckNorris Posted November 8, 2019 Share Have also been struggling with the NX.LBS has replaced entire derailleur and cassette twice , with Sram,s consent. Finally LBS "lent' me a GX setup about 3 months ago , done around 800 kms with zero problems . I have no idea as to why this helped but am just glad its working , and huge kudos to my LBS . I am not bashing Sram here , as I do think all in all their product is good. Link to comment Share on other sites More sharing options...
Dissipline Posted November 8, 2019 Share had problems shifting problems on w2w. got stuck on the big gear. see photo of what happen yesterday, buddy same problem a week back. seems new version of the derailers are out. Rev 3 Link to comment Share on other sites More sharing options...
Captain Fastbastard Mayhem Posted November 8, 2019 Share Ah yes, that's a known fault. Loctite, new jockey wheel and enough torqqque on the bolt and you're good to go. DieselnDust and slickjay007 2 Link to comment Share on other sites More sharing options...
First226 Posted November 8, 2019 Share The correct thing to do is a regular toque to be done, say monthly. You can find the correct toque setting on the Sram technical site, pre ride maintenance is important and regular service at service center where the hanger can be aligned, this lessees the pressure on the arm of the derailleur and smooths gear change. Link to comment Share on other sites More sharing options...
NotSoBigBen Posted November 9, 2019 Share The correct thing to do is a regular toque to be done, say monthly. You can find the correct toque setting on the Sram technical site, pre ride maintenance is important and regular service at service center where the hanger can be aligned, this lessees the pressure on the arm of the derailleur and smooths gear change.I can understand what you're saying here but jeez it's not a plane that needs safety checks every single time you go out ... Bikes haven't needed that type of service or check for many years why now suddenly? I just want to go out and ride my bike and check it out occasionally like I have for 30 years, is that too much to ask from someone like SRAM? slickjay007, ChrisF, Skubarra and 4 others 7 Link to comment Share on other sites More sharing options...
MORNE Posted November 9, 2019 Share https://www.evobikes.co.za/shimano-slx-rd-m7100-1x12-speed-sgs-rear-derailleur.html Or https://www.evobikes.co.za/shimano-xt-rd-m8100-1x12-speed-rear-derailleur.html. ...and be done with it. They will both work on your nx casette. Shifters available there too. And they wont need checking every ride. I havent touched my wifes 11 speed Slx groupo in months...just hose it off and go...even after the infamous k2c this year. NotSoBigBen is right....your bike is not made out of glass and should just work without any real fidgeting every single ride. Maintanence is a thing yes, but having to worry about your derailleur exploding every ride is crazy. And people tout NX as weekend warrior/enthusiast level??? At that level they need to be even more fool and bullet proof because the avarage joe does not know how to take it apart...nevermind what color locktight to use. Even the bottom of the range Alivio/altus crap just works....#just saying. Long Wheel Base, Pusher, RobertWhitehead and 1 other 4 Link to comment Share on other sites More sharing options...
DieselnDust Posted November 9, 2019 Share I agree that checking before every ride is a bit over the top but there's a simple prevention. If you have NX then do a simple one off fix. Remove the upper pulley wheel, place a drop of loctite on the bolt thread and refit. Done. Probably takes 5min. I spend more reading a bike mag while pinching a loaf. To go and spend another couple of grand on different parts seems like throwing the baby out with the bath water.It's not like sending a man to the moon Wannabe 1 Link to comment Share on other sites More sharing options...
Vishal72 Posted November 9, 2019 Share I "upgraded" from GX 11 speed to Eagle GX. It's been a disaster. Had 3 reputable bike shops in Cape Town fail to sort out the jumping gears. Eventually had the cassette and derailleur replaced under warranty. Worked as expected for the first 200km, then jumping gears again. Way too temperamental compared to the GX 11 speed and XT 2x10. Replacing it with SLX 12 speed Edited November 9, 2019 by Vishal72 Link to comment Share on other sites More sharing options...
Dissipline Posted November 9, 2019 Share Never had a problem on my slx 1x11.Think of going back to shimano. Waiting for Sram warranty claim. Link to comment Share on other sites More sharing options...
DieselnDust Posted November 9, 2019 Share I "upgraded" from GX 11 speed to Eagle GX. It's been a disaster. Had 3 reputable bike shops in Cape Town fail to sort out the jumping gears. Eventually had the cassette and derailleur replaced under warranty. Worked as expected for the first 200km, then jumping gears again. Way too temperamental compared to the GX 11 speed and XT 2x10. Replacing it with SLX 12 speed Hmmmm,do you know if the gear cable housing ends are plastic or metal? I was hanging out at my lbs this morning and a bloke came in with popular brand 2018 dual sus with GX. Complaining about shifting. I had a look over the bike while they were booking it in and sure enough the cable ends are cheap plastic jobbies. The one at the shifter end had split due to very tight cable routing. The housing also had a kink from the bar turning 180 during a crash.Those plastic cable ends are the devil's work. Then I looked over a few new bikes on the floor. Same thing. Cheap cable housing and housing ends. This is OEM spec. Yet the top end bikes had jagwire cables and housing??!!!. Bike manufactures skimp on high volume parts. Its worthwhile changing these out to better quality cable kits at the first opportunity. Link to comment Share on other sites More sharing options...
BigDL Posted November 9, 2019 Share Hmmmm,do you know if the gear cable housing ends are plastic or metal? I was hanging out at my lbs this morning and a bloke came in with popular brand 2018 dual sus with GX. Complaining about shifting. I had a look over the bike while they were booking it in and sure enough the cable ends are cheap plastic jobbies. The one at the shifter end had split due to very tight cable routing. The housing also had a kink from the bar turning 180 during a crash.Those plastic cable ends are the devil's work. Then I looked over a few new bikes on the floor. Same thing. Cheap cable housing and housing ends. This is OEM spec. Yet the top end bikes had jagwire cables and housing??!!!. Bike manufactures skimp on high volume parts. Its worthwhile changing these out to better quality cable kits at the first opportunity.Vok, I hope you didn’t offer your thoughts on this to the guys in the shop [emoji23] DieselnDust and Renier82 2 Link to comment Share on other sites More sharing options...
Register a new accountSign in
