So i had a brain wave/fart/enema.
I needed a laptop stand for Zwift - something i could reach close by and that could support a laptop and that was adjustable. Found this music stand on Takealot which works brilliantly. All for R 549.
https://www.takealot.com/bk-heavy-duty-music-stand-solid-back/PLID52753350
Use it or not - solved my problems a lot cheaper than some of the stands that i saw.
Also handlebar cellphone mounts for Zwift companion on the phone/music etc:
https://www.takealot.com/s-cape-fixed-bicycle-handlebar-mount-for-cellphone/PLID65538297
  • Replies 33
Thats what i use works very well, you can get it for half that price at a music store.
For Tablets you can also remove the top part and fix this - works really well!
http://herculesstands.com/international/products/multimedia/tablet-holders/dg305b/
The music stand works very well. I did my setup slightly differently to yours.
I used the music stand to mount a 24" screen on the front, and an Apple TV on the back. The cables are all cable tied neatly to the stand and I have a big fan standing just behind the music stand. It's a neat setup and works very well!
I bought tube steel, a can of spray paint and had some wood at home.  I then splashed on 4 wheels.
Complete cost? (I had welder, grinder etc) R340.
And honestly, it's miles better than any one I tested / saw because the bigger wheels roll nicely on my gym floor and it holds my 16" Laptop perfectly with space for a bottle or two.  Not to mention fits well around the front wheel.
It's stable as anything, but if I did it again, I'd fill the bottom piece with sand / lead / weight to have it bulletproof stable (not needed), but it may affect rolling.
Pity I dont Zwift anymore.  I literally made it 1 ride before the ban on riding outdoors lifted, and outdoors beats indoors, so fuuuuuuck that.
the reality is, that you can buy a welder, grinder, steel, wood, castor wheels and make something a little less refined but very similar for under the price of one of those.
And then sell then for R5 499.99 (on special) on the hub.
:whistling:
Wall mounted a spare 40" TV above my desk. 27" monitor below that to stream Netflix or YouTube for a a distraction while riding.
Desk is in reach for water bottles and phone.
No possible for everyone but a TV can be purchased for R2999 and a wall mount bracket is R200.
Already had the 27" monitor for work and a laptop.
