  • Replies 332
This Thread Has Taught me UDH (Universal Derailleur Hanger)
It's a Frame Standard and can be used by any bicycle manufacturer.
If It takes off (It Will) all Derailleur Hangers will be the Same or Derailleurs can be Manufactured to be Mounted directly onto the Frame by any Manufacturer.
When buying a new bike it is Wise to Consider buying a bike that is UDH Compliant.
BTW The Current Scott Spark, Spez Epic ,Spez Stumpjumper ,Giant and Cannondale amongst Others are already implementing this Standard.
Check Here Which Bikes are Compliant.
https://bikefinder.sram.com/universal-derailleur-hanger-bikes
Expand
UDH compatible frames have already taken off, chances are if you're riding a frameset from 2019/2020 it is already compatible. Plus someone will come up with a conversion solution if they haven't already.
That list from Bikefinder is a good guideline but not comprehensive, expect that it will become more so as it's updated with more niche/none US brands. Brands like Pyga and Titan Racing for example aren't on the list, yet their framesets are UDH compliant.
Expand
How do you know this ?
Can you supply some proof ?
This Merida 160 Bike Has the Whole New XX Eagle Transmission Derailleur
Edited by dasilvarsa
Expand
I can't find any pics of a cypher with the UDH and as far as I know its the latest model in their mtb line up
Expand
You have hit the nail on the head, tgefe is a good number of frames that are compatible that have been around for a while.
Expand
Good looking bike, even in that Jo Burg Lumo Green
If the gap between the smallest sprocket and inside edge of the drop out is about 4-5mm then the frame is likely UDH compatible
#i did say likely
not all compatible Frames are listed because not all manufacturers fit the sram udh. Some use their own drop that is made to fit the udh mounting template
Edited by DieselnDust
“Amish mtb components FTW” - disgruntled SRAM AXS owner.
i run a bar end shifter on my gravel bike. I like manual cars. I enjoy the involved act of cycling.
 I maintain that in an overcomplicated world I crave simplicity in the things I value most.
I see the value in this new hangerless bs…but please don't take away load-shedding addition rear derailleurs😅
Aint nobody got time (or electricity) to worry about charging a fn bicycle.
Edited by MORNE
ONE-SIXTY_10K_grntit_MY2022_03.jpg.
Expand
I freelance with some of the industry media and tech areas.
The UDH standard and T-type derailleurs have been in development over a few years. Other than comms from the marketing dept and supply chain/product managers I had seen some of original test product on the derailleurs with engineers a few months back. At the time the information was under embargo, especially for the T-type derailleurs and new drivetrains.
More recently some of the SRAM staff have also confirmed the info in discussions since the official release during Epic. SRAM also had one of their senior staffers at the Cape Epic.
Yip, that is a 2023 model, and pretty blady mooi! It’s a UDH compatible frame, which relates to the hangar. Remove the hangar and fit the new type drivetrain. On a side note, always felt Merida are woefully underrated and undervalued bikes here in S of A.
These links are helpful as well;
https://www.sram.com/en/sram/mountain/products/udh
https://www.rearmechhanger.com/product/rear-gear-mech-derailleur-hanger-cnc999/
Edited by Danger Dassie
Update
Expand
Dino, could you please provide some proof that you ARE in fact on the ground in amongst it?
You could very well just be sitting at home making this up....... 😋
Jokes aside, I think Meria made some really good bikes that perform well, but a lot of the mountain bikes hurt my eyes. They made some fantastic Enduro bikes too. I've just always been put off by the aesthetics.
#i did say likely
Expand
slapped a Vernier on my 2018 YT and it comes in at a 4mm gap...may be in luck with the UDH, just need to really test my luck on winning the Lotto in order to buy the grouppo :P
