Weight Weenie Posted March 2, 2021 Share Howzit guys Some input from those with knowledge of the Oscar V1 would be appreciated. Seems that once the pump is activated, there is water leaking somewhere, which then accumulates below the removable drip tray. When the machine was on but unused, there was no such water present, soon as I used it this morning same thing again. I used to turn the machine on to use it and then turn it off again, but it started to the trip the power when the pump activated for a few seconds while brewing. I started to leave the machine on and dry up the water after each brew, which seems to have stopped the power tripping issue at least. However near the end of the extraction the pump is also starting to make a different sound I'm not used to now, hard to describe, almost like it's pumping and stopping and so on, instead of one long pump during extraction if that makes sense. Machine is about 6 years old and has been in to 9bar for some other issues before like steam leaks, last was about 5 to 6 months ago. Any idea what the issue may be or how I can check/troubleshoot it? Keeping in mind I'm not a very mechanically minded person Thanks in advance!WW. Link to comment Share on other sites More sharing options...
Meezo Posted March 2, 2021 Share Howzit guys Some input from those with knowledge of the Oscar V1 would be appreciated. Seems that once the pump is activated, there is water leaking somewhere, which then accumulates below the removable drip tray. When the machine was on but unused, there was no such water present, soon as I used it this morning same thing again. I used to turn the machine on to use it and then turn it off again, but it started to the trip the power when the pump activated for a few seconds while brewing. I started to leave the machine on and dry up the water after each brew, which seems to have stopped the power tripping issue at least. However near the end of the extraction the pump is also starting to make a different sound I'm not used to now, hard to describe, almost like it's pumping and stopping and so on, instead of one long pump during extraction if that makes sense. Machine is about 6 years old and has been in to 9bar for some other issues before like steam leaks, last was about 5 to 6 months ago. Any idea what the issue may be or how I can check/troubleshoot it? Keeping in mind I'm not a very mechanically minded person Thanks in advance!WW.Have a look herehttps://www.elektros.it/it/en/tips_tricks.html Otherwise if you not up to opening it. Depending where you are they can check it out. Link to comment Share on other sites More sharing options...
Alouette3 Posted March 3, 2021 Share My old 80's style Gaggia Coffee is very tired, boiler to steam valve keeps blowing seals as the corrosion on the boiler is pretty bad after all these years. Been sitting idle since last week, then couldn't believe my luck when a bare bones but frame but still with an absolute mint boiler and internals pops up on Gumtree! R350 later, my Gaggia Coffee is getting a heart transplant and now becomes a full blown Gaggia Classic, finally with solenoid valves and steam switch. Very happy camper! NeverNotRolling, PhilipV, mazambaan and 5 others 8 Link to comment Share on other sites More sharing options...
MirageF1 Posted March 3, 2021 Share My old 80's style Gaggia Coffee is very tired, boiler to steam valve keeps blowing seals as the corrosion on the boiler is pretty bad after all these years. Been sitting idle since last week, then couldn't believe my luck when a bare bones but frame but still with an absolute mint boiler and internals pops up on Gumtree! R350 later, my Gaggia Coffee is getting a heart transplant and now becomes a full blown Gaggia Classic, finally with solenoid valves and steam switch. Very happy camper!When can I come for coffee? Link to comment Share on other sites More sharing options...
Long Wheel Base Posted March 3, 2021 Share When can I come for coffee?With a profile name like that, why have I never seen you post on the aviation thread? Alouette3 1 Link to comment Share on other sites More sharing options...
Alouette3 Posted March 3, 2021 Share Anyone have and old 58mm porta filter, with bust up handle etc? Want to try my hand at wood turning and make a custom handle, maybe even a naked porta filter When can I come for coffee?Was your cup of coffee that broke the last one Long Wheel Base 1 Link to comment Share on other sites More sharing options...
wonduhboy Posted March 11, 2021 Share Anyone know of any JHB (West/North) shops that have food grade lubricant?For use after cleaning an E61 group Link to comment Share on other sites More sharing options...
the nerd Posted March 11, 2021 Share Anyone know of any JHB (West/North) shops that have food grade lubricant?For use after cleaning an E61 groupI will send you WhatsApp, I got from equipment Cafe last time. wonduhboy 1 Link to comment Share on other sites More sharing options...
BikeisLife Posted March 11, 2021 Share Anyone know where to get Breville spares from? Link to comment Share on other sites More sharing options...
PlemPlem Posted March 11, 2021 Share I'm looking to buy a coffee making machine but don't know much about them.Could anyone please give me some advice on brands and what I should look out for in terms of their offering.Ideally I want a "foamer" included and obviously one that can change the strength of the coffee.My budget would be around R2500.Nespresso and get the little generic capsules. Lots of different flavours!! Link to comment Share on other sites More sharing options...
the nerd Posted March 11, 2021 Share Anyone know where to get Breville spares from? You unfortunately have to deal with @home as they hold the rights to the brand in SA. They can be and sometimes are helpful Link to comment Share on other sites More sharing options...
Muzee Posted March 11, 2021 Share Anyone know of any JHB (West/North) shops that have food grade lubricant?For use after cleaning an E61 groupMight be a bit out for you, but molykote 111 is really great http://www.molykote.co.za/Molykote-Contact.html wonduhboy 1 Link to comment Share on other sites More sharing options...
NISI Posted March 12, 2021 Share Anyone know where to get Breville spares from? Couldnt find spares myself,so i had mine repaired at coffee2u in pta. Link to comment Share on other sites More sharing options...
Long Wheel Base Posted March 12, 2021 Share Nespresso and get the little generic capsules. Lots of different flavours!!If you like coffee then that would not be the answer. RocknRolla, TheoG and the nerd 3 Link to comment Share on other sites More sharing options...
the nerd Posted March 12, 2021 Share If you like coffee then that would not be the answer.Also answering an almost 10 year old question [emoji848] Long Wheel Base and Sniffie 2 Link to comment Share on other sites More sharing options...
Reme Le Hane Posted March 12, 2021 Share Nespresso and get the little generic capsules. Lots of different flavours!!You clearly still think Koffiehuis is coffee. PhilipV, TheoG and Long Wheel Base 3 Link to comment Share on other sites More sharing options...
Register a new accountSign in
