RocknRolla Posted April 24, 2019 Share There are some known issues since the last update, certainly on the IOS mobile app.So perhaps, log a ticket with zwift help, as they are quite jacked. I got that reply from them this morning, but I am using a i7 with 16gb ram and have like 100gb free space. Its a problem on their side for sure, as I have been using zwift on the same laptop for a while now with no issues. Link to comment Share on other sites More sharing options...
dirtypot Posted April 24, 2019 Share I had the same issue with an update last year sometime - it was working perfectly, then updated, then my system was too low spec. I went through the whole support system with multiple different people trying to fix the issue, but in the end they said it wouldn't work anymore and they were phasing out the things which allowed the old systems to work as they were clashing with the newer systems. It was an old graphics card driver issue on mine - the update required drivers to be newer than a certain age, but my old card had no newer drivers available and therefore wouldn't run Zwift anymore. I tried all sorts of new graphics drivers which would work on my card but nothing solved the problem and I was losing more hair over it. In the end I just got a new graphics card. In hindsight I wish I had done it ages ago as it made my PC much more usable and quicker. Also replaced the HDD with an SSD two weeks ago, and these two changes have taken my PC up to a 6.8 rating out of 7 on the Windows performance index, so I'm happy. In the end I conceded that Zwift can't keep making their systems run in a backdated way to enable my crappy old system to continue working. Evolution. I upgraded and moved on, and I'm a happier better person for it RocknRolla 1 Link to comment Share on other sites More sharing options...
Veebee Posted April 24, 2019 Share Logged a ticket and busy trying out different things but nothing is working.Trying to download on another laptop and will see from there. Quite frustrating. Their support basically gives us standard replies. Link to comment Share on other sites More sharing options...
Veebee Posted April 24, 2019 Share Just tried on my sisters laptop. its a 1month old i7 with the latest of everything... Guess what, same error. Definitely a problem on their end. Link to comment Share on other sites More sharing options...
Dexter-morgan Posted April 24, 2019 Share Could anyone suggest a Cheap alternative to buying a new laptop? or what spec laptop will work? I see Matrix has some cheap ones but they are celeron, do I need a Proper graphics card? Link to comment Share on other sites More sharing options...
RocknRolla Posted April 24, 2019 Share Could anyone suggest a Cheap alternative to buying a new laptop? or what spec laptop will work? I see Matrix has some cheap ones but they are celeron, do I need a Proper graphics card? Can you not load on mobile device? Link to comment Share on other sites More sharing options...
Muttley Posted April 24, 2019 Share Could anyone suggest a Cheap alternative to buying a new laptop? or what spec laptop will work? I see Matrix has some cheap ones but they are celeron, do I need a Proper graphics card?I purchased an Intel NUC i3, 7th Generation with 8GB of RAM and a 500GB HDD off Carbonite from JazzyC for R2500. It's worked brilliantly so far- maybe get in touch with him, and see what he can help with. https://carbonite.co.za/index.php?threads/8th-gen-intel-nuc-i3-8gb-ddr4-ram-500gb-hdd-r3000.241444/#post-1652502 Andrew_Smith, Dexter-morgan and shaper 3 Link to comment Share on other sites More sharing options...
thisismyotherbike Posted April 24, 2019 Share Could anyone suggest a Cheap alternative to buying a new laptop? or what spec laptop will work? I see Matrix has some cheap ones but they are celeron, do I need a Proper graphics card? If you want to use it with an existing screen or television, there's the Apple TV. Super simple and performs well. Takealot are selling the 4K version for R2.9k. Will outperform a cheap laptop. Note that you'll need a trainer that has BLE as the Apple TV doesn't do ANT+. Vetplant and dirtypot 2 Link to comment Share on other sites More sharing options...
BigDL Posted April 24, 2019 Share Could anyone suggest a Cheap alternative to buying a new laptop? or what spec laptop will work? I see Matrix has some cheap ones but they are celeron, do I need a Proper graphics card?Use your iPhone or iPad Link to comment Share on other sites More sharing options...
Adrian Fogg Posted April 24, 2019 Share Using my Huawei Mate 20 Pro to run ZWIFT works fine. Link to comment Share on other sites More sharing options...
OnTheRicky Posted April 24, 2019 Share What's the best way to do a free ride but make sure I hit my TSS in a set time? I basically want to aim for a 1h30m ride and get ~70TSS while in sim mode Link to comment Share on other sites More sharing options...
RocknRolla Posted April 24, 2019 Share What's the best way to do a free ride but make sure I hit my TSS in a set time? I basically want to aim for a 1h30m ride and get ~70TSS while in sim mode Pretzel route. Alternatively look at the workouts, and do one of those. The workouts are divided into time: less than an hour, more than an hour, etc. Link to comment Share on other sites More sharing options...
shaper Posted April 24, 2019 Share What's the best way to do a free ride but make sure I hit my TSS in a set time? I basically want to aim for a 1h30m ride and get ~70TSS while in sim modeRearrange the TSS equation to work out what NP you have to ride at for 1hr30 to hit your 70 TSS, Do a number of calcs with different IF's if needed https://www.trainingpeaks.com/blog/estimating-training-stress-score-tss/ Else try the calc based on RPE and adjust every 30 mins OnTheRicky 1 Link to comment Share on other sites More sharing options...
OnTheRicky Posted April 24, 2019 Share Rearrange the TSS equation to work out what NP you have to ride at for 1hr30 to hit your 70 TSS, Do a number of calcs with different IF's if needed https://www.trainingpeaks.com/blog/estimating-training-stress-score-tss/ Else try the calc based on RPE and adjust every 30 mins Perfect - this should work! Link to comment Share on other sites More sharing options...
Andrew_Smith Posted April 24, 2019 Share I purchased an Intel NUC i3, 7th Generation with 8GB of RAM and a 500GB HDD off Carbonite from JazzyC for R2500. It's worked brilliantly so far- maybe get in touch with him, and see what he can help with. https://carbonite.co.za/index.php?threads/8th-gen-intel-nuc-i3-8gb-ddr4-ram-500gb-hdd-r3000.241444/#post-1652502 +1 Carbonite FTW. I am a moderator on the forum. Loads of trusted reseller selling PCs/laptops to start your Zwfiting. Just check the feedback score of said user before buying and Bob's your uncle. And please read the forum rules when creating an account Muttley 1 Link to comment Share on other sites More sharing options...
OnTheRicky Posted April 25, 2019 Share Rearrange the TSS equation to work out what NP you have to ride at for 1hr30 to hit your 70 TSS, Do a number of calcs with different IF's if needed https://www.trainingpeaks.com/blog/estimating-training-stress-score-tss/ Else try the calc based on RPE and adjust every 30 minsI messed this up because long steady state sessions are boring... so with the few sprints I did here and there I completely overshot my target. For my next attempt I'll connect my Elemnt Bolt and keep an eye on Normalised Power and 30sec average power and try and keep that steady for the most part. Curious to know if anyone else does something similar? Link to comment Share on other sites More sharing options...
Register a new accountSign in
