Wood glue puncture repair
Sepia
Might be of interest......somebody might have tried it previously.
I plugged a large puncture in a tubeless tyre and after a while it started to leak again.  The tyre was still in good nick so decided to MacGyver it as I had nothing to repair it with, or so I thought.
I opened the tyre and squirted some Alcolin over the leaking plug and worked it into the leak and the plug fell out.  I let it congeal for a bit, added about 60ml Alcolin to the sealant and pumped up.  After 600kms the hole is still sealed and all is good.
Maybe the tyre will be difficult to remove ????
Link to comment
Share on other sites
9 hours ago, ACM said:
Had a side wall cut that I plugged, but it kept loosing air with the tyre flexing. Put sikaflex around the plug and problem solved.
works wonders on slightly torn/ripped bartape too.
Link to comment
26 minutes ago, Jewbacca said:
The best solution for plugged tires is to take the tire off, take the plug out, clean it and patch it on the inside with a piece of latex strip.
Just saying.
I got a piece of 0.4mm Diaphragm rubber from supplier, works like charm, it is nicely re-enforced with fibers as well.
Link to comment
Just saying.
latex or strip of old butyl inner tube
Link to comment
Why are we all getting stuck into this one? Maybe its cold out?
Edited by 117
Link to comment
