2 minutes ago, Vetplant said:
Yep, the cost thing can obviously be easily overcome. Took one of my wife's old discarded deep sauce pans and I cook up my brew on the electric stove whenever needed. Afterwards I just leave the mix in the pan to cool down and set, then store it away until I need it again.
The main benefit for me is that the lube actually gets into the places where it is needed if you "cook" it in the pot/pan. Drip dry and then wipe with a paper-cloth, nothing left on the outside to attract dirt and grime, the chain stays clean for very long.
Same, I negociated to steal a glass tupperware, that I put in one of our pots, pour boiling water around it and keep it on the stove to keep it warm. Then it's free (or close to free, because I did promise I would replace that tupperware). She wouldn't let go of one of our pots or pans, since we have induction those are actually more pricy than a slow cooker ;)
  • Replies 191
You just made me Google 'glass tupperware'.🤔
Why a slow cooker?
a stove is ample to get the mix up to 180c
44 minutes ago, DieselnDust said:
I just use wax, special oil and a special additive called obtainium…
peasant.
Nothing special about adding stuff anybody can obtain from anywhere.
It will be so much more exclusive and secret with unobtanium...
1 minute ago, MORNE said:
peasant.
wel it was used in the Russian space program….
1 minute ago, dasilvarsa said:
You can also use commercially made lube (Squirt or Other) to do a Deep, Warm, Soak.
No bra , there’s nothing like a bit of alchemy accompanied by wizards chants while sprinkling things into a pot to buy one some free time. Wear a pointy hat and the house is yours for the day
In the 60/70 and 80's before the fancy 8 9 and 10 speeds with thin chains made of lighter material i waxed my chai as well . I used natural bees wax ( have a friend who is a bee farmer ) . I washed the chain in  paraffin , let it drip dry and then had a tin can with a handle on and  chuck in a lump  of bees wax  on the stove . The rolled up chain fitted precisely into the tin with hot wax  on the stove . I left it in for about 5 minutes to really get into the rollers and then hung it up again wiping off with non lint cloth . That waxing would last at 3 to 4000 kms of riding ( 2 to 3 months ) . I still have the can and some bees wax .
Bees wax is good stuff, very tacky though which has good properties and not so good (like attracting dirt) but the tackiness keeps it in place.
You guys should know that a prominent poster here is a lubrication and application specialist...... He occasionally shares some wisdom worth heeding...
